Can I use a copper 3/4 to 1/2 sweat in a brass female ibox connection?
Smokedvw
Vancouver, Canada
Hi,
The local store ran out of brass connections, can I use a copper 3/4 mntp into the brass 3/4 female on the ibox?
Thank you
wwhitney
Berkeley, CA
Certainly, if you solder in the piece of copper pipe first, then make up the connection with the usual pipe dope and/or teflon tape. And if 1/2" copper is a sufficiently large supply, depending on what outlet you have on the iBox.
Cheers, Wayne
Smokedvw
Vancouver, Canada
Cheers, Wayne
Ok great
Off to the garage to solder and then attach to the box
Our only concern was getting the turns right and not over tightening to make it fit back correctly with the pipes pointing down to attach.
