I am replacing an elbow fitting on the cold water side of my RVs aluminum hot water tank. First I replaced a plastic elbow with another plastic one, used RectorSeal pipe sealant, reconnected to pex piping and it leaks at the threads connection to the tank. Max psi is 55 in the line.
Next I am thinking of using a brass elbow with pipe tape sealant.
Question: is it possible to be sure the seal of the fitting to the tank will not leak before I connect all pex fittings and power up the pump?
It's a 1/2 inch standard thread connection to tank.
Note, obviously I am very inexperienced at this and would appreciate your advice on how to not just create another leak.
Happy New Year and thanks.
