Can a female union tailpiece be used for male NPSM threads?
Brandon Weiss
Santa Cruz, California
I have a device that has 1" male NPSM (straight) threads on both ends and I want to adapt it to 1" NPT. The instructions say to get two water meter fittings to make the connection to NPT, but water meter fittings are typically asymmetric (1-1/4" NSPM to 1" NPT or 1" NPSM to 3/4" NPT).
I’m wondering would the female half of a union (like this one) work? Naively it seems like it would, but I don’t know if unions are always (or even typically) NPSM threaded, or if they’re just some random straight threads that aren’t standardized.
Thanks for your help!
The part that you linked to isn't going to help you. The female threads will be NPT, and the other side will be a flat plate with a o-ring meant to mate with a similar plate on the Watts PRVs listed.
You need a fitting with 1" NPSF threads that accepts a washer for sealing. Since the straight threads won't provide a seal.
While inelegant, if you are forced to use a 1" NPSM to 3/4" NPT part but want to stick with 1" piping, a short section of 3/4" typically isn't going to cause any problems. It will be equivalent to something like 5 times the length of 1" piping.
Cheers, Wayne
