Cabinet guys cut pipe short- Is this enough pipe for drain?
PepeLePue
Chicago
Cabinet guys cut this way short, if I attach wye here to add drain + clean out is that connection point going to leak? Should I get the hub saver instead and attach longer pipe or is that riskier? 2” pvc.
Have a few other similar ones, what’s the minimum length I should feel ok about using?
Thank you!
PepeLePue
Chicago
Assuming the stub out is good enough, is this a quality setup?i just dry fit it, any room for improvements? Was debating finding a wye that had 1-1/2 straight out and 2” off to the side instead. This is all I had at the moment though.
marginal , probebly ok but a good idea to remove the pipe from the hub and glue in a new stub
Tuttles Revenge
While its less than ideal, the fact that its exposed makes the risk minimal.
I think your configuration will work fine.
Sylvan
Still learning
New York
I personally would not trust it BUT you may want to get a PVC coupling and measure the inside cup then if it is deep enough for the pipe to fit most of the way then just add a nipple on the other side
PepeLePue
Chicago
You're saying the coupling may have a shallower connection than the wye?
I think the wye is for a cleanout but if its just 1 1/2 Id just use a tubular ptrap unless you anticipate running a snake often.
The issue is you only got a bit of pipe to glue to all hubs are standard depth . Just take your pick glue it up or get that bit out by using a ram bit or the old fasioned way of cutting it and using heat
PepeLePue
Chicago
Correct, want to include a cleanout. However, using a 2x2x2 wye, I would have to use a bushing or reducer out of the center. Thats why I want to pick up the 2x 1.5 x 2 wye, so I can avoid using a bushing. I don't think enough space to use a reducer anyways. Just looks neater/cleaner and easier to snake since the p-trap wouldn't be blocking access to the clean out.
Fully intend to use tubular p-trap. I had thought about a LA trap but will probably just return all of those fittings I bought to keep it simple and easy to install.
GReynolds929
Active Member
WA
I think the bigger question here is why did the cabinet guys touch your plumbing?...
Tuttles Revenge
What would you do if it was your sink?
I ordered this I think I'm going to switch out the wye to one of these to use less fittings.
Dishwasher set up works too?
If it were me and I didn't own the $60 tool to simply ream out the pipe from the socket that takes about 1 minute to accomplish, I would just glue it up as is. All ABS and PVC fittings under 3" have 3/4" depth sockets so a coupling will be the same depth as that WYE fitting... which I have Never in my life seen!
watch out for knock off brands...
to install the cabinet long stub outs get wacked sometimes , I dont like it but choose your battles I been known to take a saw to a cabinet as well LOL so many trades are dumb AF at least leav an inch and nobody would care. ok cource an easy fix we dont need no tool. tiny tim saw, a screw driver and possibly some heat off the torch gettr done !
PepeLePue
Chicago
Tuttles Revenge
I found this in my plumbing bag. Must have bought it when i found it on sale a while back. Good enough or is this one of the knock offs?
I haven't used that version, but it looks like its made to do the same job. Pic says Reed, but its amazon so I'm always leary of scammy products. Easy test would be to see if it fits snugish into the 2" socket of a random fitting and fits the front part into 2" pipe.
PepeLePue
Chicago
Great, thank you for your help, always appreciated!
Good eye Ive bought quality stuff off amazon and Im not skitish at all about it but .... I clicked on the Reed Store and its some sort of leather store, Ive never used a reed genuine reamer but that thing looks kinda cheezy like my 10 dollar ram bit with some red paint well not quite but I think its a knock off . Im very leary of that particular item!
PepeLePue
Chicago
Just quick update here. The bit worked it seems. Took some time to cut through all of that but ultimately works. Left a small OD around the cut area of the old pipe but with the friction from cutting it basically peeled off. Hole left behind was a little loose but I used a ton of primer and glue and seems to be holding up ok.
I used a street 45 off the wall to slightly offset the wye so wouldn’t bump into my tailpiece. Definitely thankful for all of the extra parts I bought vs running back and forth to the store!!
Pic below any constructive feedback welcomed! Thanks for the help everyone
