Hi, I have been browsing these forums hoping to find someone else describing my current scenario but have not found anything. After talking with Bosch support and a few local plumbers I am still at a loss for if this is normal behavior for the system and was hoping someone here could help before I pay to have a technician come to the home (unfortunately the plumber who installed the system moved out of state and is not reachable)
I have a Bosch Greenstar Combi unit.
Briefly the situation is this: after using the hot water for a task, the next time I use it, either it takes considerably longer to reheat, or will start hot and then become ice cold for 2-4 minutes.
As an example, say my wife takes a shower, and then some time later, even right away, I take a shower. The water will either take longer to heat up, or the water will heat up normally, and then turn ice cold for 4 minutes before heating back up again. I did try not turning the water off inbetween the showers to see if it was some sort of time dependent event, but the water stayed hot throughout both showers if the water is never turned off.
Is this normal behavior of the heater? Some sort of safety mechanism? The same situation occurs no matter which use of hot water (either shower, sinks, dishwasher, etc).
I appreciate any help or thoughts offered! Thank you.
