Hi,
I have just had a 10hp bore hole pump re connected to the electricity supply and water is pumping just fine, one question I have is what would happen if the valve which connects the water from the pump to the irrigation system was closed and the pump was switched on, would there be a huge build up of pressure or something and blow something on the pump, or do pumps have some sort of pressure switch to stop this ?
Thanks
Scott
Thanks
Scott
