Hi, I'm new here & desperately looking for advice. I took out old tub & galv drain pipe broke off leaving threads in lower pipe. Plumber told me to use black cement & acrylic caulk to join pvc to site. That doesn't work!! Its about a foot down in the hole. Put a coupling reducer on the end of the pvc to fit into galv pipe.
I've gone to all the plumbing stores & most said a banded something would join these pipes, but because its at the joint, the rubber won't fit over it. Is there some way to cut the flared joint off of the galv? Your help would be ever so appreciated.
JAM45
JAM45
