Basement floor drain rules
Phil P.
Arlington, Virginia
Greetings all and happy 2022!
I'm planning a basement renovation I want to include a floor drain in the utility room.
I plan a 2" pvc pipe with a p-trap, and keep it within 8ft trap arm length max for venting.
Is there any code requirement to have some sort of of system to keep trap from evaporating dry?
And if I add a similar floor drain to an upstairs laundry room, same question, any requirement to keep the trap wet?
Thanks much .. Phil
John Gayewski
Iowa
I actually think the cast iron enamel floor sinks are better for draining. Floor drains are for emergency only in my opinion. Continuous draining like a condensate line needs a better surface.
There is no requirement, but a trap seal protection system is useful.
Phil P.
Arlington, Virginia
Thanks for the information folks! Yes it will be emergency/just in case floor drain. I'm well aware that trap water may evaporate and needs periodic refreshing .. I'll look into tap primer. Good week everyone! Phil
