Watersoftenerhelp
Hi, I've been in this house for 2 summers and this summer i'm having a problem with my sprinkler system. During the winter I discovered my expansion tank for my well (4.8 gallon) was bad so i replaced the well. I ended up blowing out my owner sprinkler system during the winter as well.
This summer, when my sprinkler change zones, I get a really bad water hammer whenever a new zone opens. I thought maybe the zones were opening too rapidly so what I did was put a minute delay inbetween each zone.
I have a BF20 constant well pressure controller, with a 33GPM Goulds 2 HP well pump.
When my valve is open for my sprinkler system I can tell I have a leak. My gauge will go from 75PSI to 68 PSI bleed *I have a 4.8 gallon expansion tank* that will end up bleeding out in a matter of 10 minutes.
I dont know if this problem is a new problem or not.
I also checked my valve boxes and I did have a few leaking valves that I had repaired. But i still have a leak in my system somewhere to bleed out every 8-10 minutes.
When the zones change my pressure gauge drops to 40PSI rapidly and my gauge dances around for a while. That ends up seeming to cause water hammer and my expansion tank doesn't like that. (it seems to only happen when my sprinkler have sit for more than a few hours, i'm guessing the water has enough time to bleed out of the pipe leak?)
My question is, could my problem be the main sprinkler line bleeding out or having air in it and everytime it has to change zones it has to fill that entire pipe up again and my zones?
I've been looking for 4 days straight (10 hours a day) for a wet spot, fungus, sinking, bubbling soil. I also filled the zones up with air and walked my property to see if i can hear any hissing.
I'm kind of at a loss at this point. Could my expansion bladder also be too small for my system?
