Artesian Well Causing Air in Lines
miket0813
Osceola Twp, MI
We have a 1400 sq ft cabin with a constant flowing artesian well. The well fills up a storage tank in the crawl space, and overflows to the river. There is a 1/4 hp jet pump that comes off of the storage tank and a 52 gallon pressure tank behind the pump. The system seems to be operating fine, but we are getting massive amounts of air from all of the faucets. This has been going on for quite some time, and may possibly have started with the addition of the larger pressure tank. Any thoughts?
miket0813
Osceola Twp, MI
May have happened when you installed the tank. But most likely you have a leak on the suction line somewhere.
You are thinking a leak between the storage tank and the pump? If so, I cannot see anything. The tank has a foot of pipe, then the check valve, then 3 feet of pipe, then the pump.
miket0813
Osceola Twp, MI
You can't see an air leak. Having a foot valve and a check valve is not good and could be part of the problem.
No foot valve, just the check valve between the storage tank and the jet pump. Maybe I will just replace that section of pipe, and replace the check valve as well?
miket0813
Osceola Twp, MI
I purchased a new poly storage tank...200 gallons, and was planning to just replace the old metal tank that is in place today. I am now wondering if I should completely change the setup and use the submersible Hallmark pump I keep reading about. The tank has a removable lid that screws down. It also has a 1.5" fill towards the top and 1.5" drain towards the bottom. Both of those are threaded. How would I use the submersible pump with this tank? I know that I would tie the artesian well input into the top 1.5" fill opening, but more interested in how to make the cistern water-tight with the hallmark pump inside. The well has a constant flow of about 1.5 gpm.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
With a little caulking you could make it watertight. But that tank will need a vent anyway, and a little venting around the wire or well seal won't hurt. Without caulking it should at least be bugsafe. Lol!
I would use 1" PVC or poly.
