Are My Drains and Vents Correct?
MikeGA
North Jersey
I redid my entire DWV system in the house. Three and a half bathrooms one kitchen and a laundry room. I have been doing plumbing for quite a while but this is the first time I undertook such a large project myself. I'm curious as to if my fittings are the correct ones. I'm asking because I realize there are a lot of rules with what bends can and cant be used and I think I've used all the right ones.
Yes and I thought I saw that horizontal to vertical using a sanitary tee is acceptable.
That is the acceptable use everywhere. The fitting I commented on is horizontal to horizontal.
Yes.
Also, in UPC, that vertical to horizontal elbow would have been a long sweep or two 45s. I think you used a regular bend, which I think is OK in IPC. That longer sweep would have been more important for kitchen drainage IMO.
MikeGA
North Jersey
Yes.
So even though the left side of that tee is a vent and the right side is a drain, you still think its unacceptable? That is the vent for the tub.
I think that, if the objective is to conform to code.
