Aquanot II questions
coolcitybbq
WI
I have an Aquanot II being shipped soon, I have the following questions:
The instruction manual shows the primary pump on a brick at a higher level. Is this required or can both pumps sit flat in the crock but with the backup set to turn on at a higher water height?
I notice the discharge line doesn't require a 1/4" hole near the bottom to prevent air lock. Is this because the pump is a pedestal design?
Any battery suggestions? I'm interested in whatever design will run the longest continuous time, such as the Size 31 Water/Acid battery. Maintaining it monthly with distilled water is not an issue for me. So is the Aquanot battery the only Wet battery with 200 min of reserve time or are there other trusted manufacturers?
Anyone know where I can buy a SJ Rhombus Vertical Master switch, I only found one vendor online.
Thank you
Dave
