Any tips for getting supply pipe in the coupler with tank below?
Mike00777
Georgia
I think all I can do is hope the pipe gives enough for me to raise it up and push it into the final coupler? Seems really tricky.
Phog
Active Member
Rochester NY
You need a copper slip coupling. Almost the same as a normal coupling but it has no stop inside, enabling you to slide it back all the way onto a pipe (instead of stopping you when pipe gets halfway into the fitting).
Mike00777
Georgia
Thanks. I feel so ignorant for not knowing about the slip coupler without the notches! I ended up using a flex hose on the hot side, and a union on the cold side. I had a slip coupler and thought, gee whiz this cheap POS wasn't notched!
