Any glaring issues with DWV?
gsutt
cincinnati
Are there any glaring issues that I should correct before I glue? Thanks in advance for any input.
I guess not any glaring issues, its odd to have 2 inch trap arms on the double lavs. Not so sure about the holes in joists. Id be a little nervous if its getting inspected plumbing looks like its got grade if its fit up well and dont leak it should perform well. Let us know if it passes or if they inspect plumbing or framing there. Good luck , itll probebly pass IPC code!
gsutt
cincinnati
Thanks. Jeff. I’ll switch that 2” out for 1.5”. I’m going to reinforce the joists with Metwood joist reinforcements. Holes were here before me so I’m hoping it passes. Thanks for your input.
Your welcome and good luck with inspection , sound like your hands kind of tied since holes were allready there Ill look at " Metwood" . If its existing and no issues should be ok assuming you dont add to floor load
