Anode Rod Replacement
Discussion in 'Water Heater Forum, Tanks' started by Cityslacker06, Apr 25, 2021.
  1. Sarg
    Sarg Enjoy Learning
    Nov 6, 2020
    Recently retired
    NorthEast
    And just another tip when installing a replacement.
    Obtain a drain valve ( full 3/4 " ball valve ) that is specifically made to flush sediment and install during the installation.
    The factory drains are a compression shut off that will not pass sediment.
    ( Valve is about $27 )
    Cityslacker06 likes this.
  2. Cityslacker06
    Cityslacker06 New Member
    Apr 25, 2021
    Salem, OH
    Yessir. I will keep this in mind when the time comes.
  3. Cityslacker06
    Apr 25, 2021
    Salem, OH
    Great information, sir. I will keep this in my memory banks as well.
  4. myhouse
    myhouse New Member
    Apr 27, 2021
    Montana
    Try a piece of pipe.
    Seriously, use whatever socket you have, then put a 3 or 4 foot long piece of iron pipe on the breaker bar. That will give you all kinds of leverage. But - beware of the possibility of flying (face-first) in to the wall when the anode breaks free (or the breaker bar breaks!).
  5. Cityslacker06
    Apr 25, 2021
    Salem, OH
    Since I am an amputee, I will not try this by hand because I know I will lose my balance and knock myself out. I tried once already, and it did not work out very well. I will get a regular air compressor (not the pancake style) and try using a pneumatic impact again. The pancake style will not work since it can not keep up with the wrench. I have tried this already as well. Another issue is do not have anyone else to help me.
    myhouse likes this.
  6. SShaw
    SShaw Member
    Nov 17, 2019
    Virginia
    That would not have worked for me for two reasons. 1) There's no room in the utility closet for that long of a breaker bar. 2) Using a bar you need to have a second person hold the tank and apply equal torque in the opposite direction, which isn't practical.
    An air impact wrench solves both of these issues. Because it hammers the fastener at >20 times per second, rather than applying constant torque, you don't need a second person to secure the tank.
Similar Threads: Anode Replacement
Water Heater Forum, Tanks Anode rod replacement surprise May 3, 2021
Water Heater Forum, Tanks Water Heater Replacement with Powered Anode help removing the old WH Jul 17, 2020
Water Heater Forum, Tanks Rheem Hot Water Heat Pump Anode Replacement Jun 4, 2019
Water Heater Forum, Tanks Can replacement of older tank with tiny leak at top (anode) be delayed? Jan 21, 2019
Water Heater Forum, Tanks Replacement Anode in Rheem heater May 27, 2017
