10 years ago I had a Aermotor T20, 3/4 hp, 20 gpm, 2 wire pump installed on my 6" drilled well. Our water is on the acidic side and we have iron. Every 2-3 years I pull the pump and clean the inlet screen and put new 1" pvc pipe on. The well is only 25 feet deep and the pvc pipe is 17 feet long. This pump is used for our house water and also our sprinkler system. I noticed our pressure with the sprinkler system on was down to 36 psi, so I figured the pump was getting plugged again. I recently cleaned the screen and put new pipe on. When I run my sprinkler system now it maintains 48 psi. Normally after cleaning and new pipe I can hold 56 psi. Could this be a sign that the impellers are plugged or worn and the pump nearing the end of its life. If the pump was used only for house water we wouldn't know there was any problem going on. I tried to look this pump up online, but can't find anyone who sells Aermotor.
