TX-Tim
I'm currently in the process of getting a home built and wanted to prepare for getting a carbon filter/softner installed in Georgetown, TX area. Our previous home (Dallas) had a Rainsoft system installed, so we know we want to go back to a softner, especially since the rental we are in not does not have anything. I am just not looking to pay Rainsoft $$$.
The house will be roughly 3000 ft2, with 3.5 bathrooms. There are 2 adults + 2 kids (under 6).
With all the information out there, I've not 100% sure on what size the system needs to be.
Current water usage: varies between 4-6K gallon a month, but want to ensure it is sized for when kids get older.
I purchased a water test kit (Health Metric) and got the following from the model house:
** City Water **
pH: 9.5
Alkalinity: 500 ppm
Chlorine: 1.0 ppm
Hardness: 250 ppm
Nitrate: 0
Nitrite: 0.2 ppm
Copper: 0.05 ppm
Iron: Color seemed to be between 0 & 0.3 ppm
** Is this test kit ok, or should I get a "real" test **
The water loop installed is 1" PEX tubing.
If have been looking at the Fleck 5810 valves
I know I want 10% crosslinked resin, but not sure if 1.5 or 2.0 ft3 is needed as I want to ensure this is good as the kids get older. Rainsoft person only recommended 1.0 ft3
The city report shows they use Chloramine, so I know it needs to be Catalytic Carbon, but again, 1.5 or 2.0 ft3. The Rainsoft system we had in Dallas was not back washing, but I am leaning toward one.
I'm also include a picture of the water loop and drain pipes. I'm used to seeing them vertically over each other. Which is intended for the drain and which is the clean-out? I'm thinking the first one from vent line is the clean-out (one on right).
Also, is there any real benefit to doing a sediment filter in front of everything? For some reason I found myself trying to model the Aquasana setup.
Thanks for any comments, suggestions, or insights you can provide.
** City Water **
pH: 9.5
Alkalinity: 500 ppm
Chlorine: 1.0 ppm
Hardness: 250 ppm
Nitrate: 0
Nitrite: 0.2 ppm
Copper: 0.05 ppm
