SELECT data_key, data_value
FROM xf_data_registry
WHERE data_key IN ('options', 'languages', 'contentTypes', 'codeEventListeners', 'deferredRun', 'simpleCache', 'addOns', 'defaultStyleProperties', 'routeFiltersIn', 'routeFiltersOut', 'routesPublic', 'nodeTypes', 'bannedIps', 'discouragedIps', 'styles', 'displayStyles', 'userBanners', 'smilies', 'bbCode', 'threadPrefixes', 'userTitleLadder', 'reportCounts', 'moderationCounts', 'userModerationCounts', 'notices', 'userFieldsInfo')
Run Time: 0.000675
Select Type | Table | Type | Possible Keys | Key | Key Len | Ref | Rows | Extra |
SIMPLE | xf_data_registry | range | PRIMARY | PRIMARY | 27 | | 26 | Using where |
SELECT cache_value
FROM xf_permission_combination
WHERE permission_combination_id = ?
Params: 1
Run Time: 0.000195
SIMPLE | xf_permission_combination | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT thread.*
user.gender, user.avatar_date, user.gravatar,
NULL AS thread_read_date,
0 AS thread_reply_banned,
0 AS thread_is_watched,
'' AS draft_message, NULL AS draft_extra
FROM xf_thread AS thread
LEFT JOIN xf_user AS user ON
(user.user_id = thread.user_id)
WHERE thread.thread_id = ?
Params: 88436
Run Time: 0.000399
SIMPLE | thread | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | user | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SELECT node.*, forum.*
permission.cache_value AS node_permission_cache,
NULL AS forum_read_date
FROM xf_forum AS forum
INNER JOIN xf_node AS node ON (node.node_id = forum.node_id)
LEFT JOIN xf_permission_cache_content AS permission
ON (permission.permission_combination_id = 1
AND permission.content_type = 'node'
AND permission.content_id = forum.node_id)
WHERE node.node_id = ?
Params: 10
Run Time: 0.000491
SIMPLE | forum | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | node | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | permission | const | PRIMARY | PRIMARY | 35 | const,const,const | 1 | |
SELECT post.*
user.*, IF(user.username IS NULL, post.username, user.username) AS username,
user_profile.*,
user_privacy.*,
session_activity.view_date AS last_view_date,
0 AS like_date
FROM xf_post AS post
(user.user_id = post.user_id)
LEFT JOIN xf_user_profile AS user_profile ON
(user_profile.user_id = post.user_id)
LEFT JOIN xf_user_privacy AS user_privacy ON
(user_privacy.user_id = post.user_id)
LEFT JOIN xf_session_activity AS session_activity ON
(post.user_id > 0 AND session_activity.user_id = post.user_id AND session_activity.unique_key = CAST(post.user_id AS BINARY))
WHERE post.thread_id = ?
AND (post.position >= 0 AND post.position < 20)
AND (post.message_state IN ('visible'))
ORDER BY post.position ASC, post.post_date ASC
Params: 88436
Run Time: 0.001569
SIMPLE | post | range | thread_id_post_date,thread_id_position | thread_id_position | 8 | | 1 | Using index condition; Using where; Using filesort |
SIMPLE | user | eq_ref | PRIMARY | PRIMARY | 4 | terrylove_xenforo.post.user_id | 1 | |
SIMPLE | user_profile | eq_ref | PRIMARY | PRIMARY | 4 | terrylove_xenforo.post.user_id | 1 | |
SIMPLE | user_privacy | eq_ref | PRIMARY | PRIMARY | 4 | terrylove_xenforo.post.user_id | 1 | |
SIMPLE | session_activity | eq_ref | PRIMARY | PRIMARY | 22 | terrylove_xenforo.post.user_id,func | 1 | Using where |
INSERT DELAYED INTO xf_thread_view
(thread_id)
VALUES
Params: 88436
Run Time: 0.000142
SELECT *
FROM xf_node
ORDER BY lft ASC
Run Time: 0.000498
SIMPLE | xf_node | ALL | | | | | 37 | Using filesort |
SELECT content_id, cache_value
FROM xf_permission_cache_content
AND content_type = 'node'
Params: 1
Run Time: 0.000309
SIMPLE | xf_permission_cache_content | ref | PRIMARY | PRIMARY | 31 | const,const | 36 | Using where |
SELECT params
FROM xf_session_activity
WHERE user_id = '0'
AND controller_action = 'CreateThread'
Run Time: 0.001053
SIMPLE | xf_session_activity | ref | PRIMARY | PRIMARY | 4 | const | 1912 | Using where |
SELECT xf_thread.thread_id, xf_thread.title, xf_thread.node_id, xf_node.title AS nodetitle, xf_thread.post_date
FROM xf_thread
INNER JOIN xf_node ON xf_node.node_id = xf_thread.node_id
WHERE xf_thread.title LIKE '%Adding%'
AND xf_thread.title LIKE '%Drip%'
AND xf_thread.discussion_state = 'visible'
AND xf_thread.discussion_type <> 'redirect'
AND (xf_thread.node_id = 25 OR xf_thread.node_id = 6 OR xf_thread.node_id = 3 OR xf_thread.node_id = 36 OR xf_thread.node_id = 37 OR xf_thread.node_id = 38 OR xf_thread.node_id = 39 OR xf_thread.node_id = 5 OR xf_thread.node_id = 4 OR xf_thread.node_id = 22 OR xf_thread.node_id = 21 OR xf_thread.node_id = 15 OR xf_thread.node_id = 16 OR xf_thread.node_id = 17 OR xf_thread.node_id = 18 OR xf_thread.node_id = 19 OR xf_thread.node_id = 7 OR xf_thread.node_id = 26 OR xf_thread.node_id = 27 OR xf_thread.node_id = 28 OR xf_thread.node_id = 30 OR xf_thread.node_id = 31 OR xf_thread.node_id = 29 OR xf_thread.node_id = 40 OR xf_thread.node_id = 9 OR xf_thread.node_id = 13 OR xf_thread.node_id = 12 OR xf_thread.node_id = 10 OR xf_thread.node_id = 35 OR xf_thread.node_id = 32 OR xf_thread.node_id = 24 OR xf_thread.node_id = 11 OR xf_thread.node_id = 34 OR xf_thread.node_id = 23 OR xf_thread.node_id = 33 OR xf_thread.node_id = 8)
AND xf_thread.thread_id <> '88436'
AND xf_thread.node_id = '10'
ORDER BY xf_thread.thread_id DESC
LIMIT 5
Run Time: 0.068127
SIMPLE | xf_node | const | PRIMARY | PRIMARY | 4 | const | 1 | |
SIMPLE | xf_thread | index | PRIMARY,node_id_last_post_date,node_id_sticky_state_last_post | PRIMARY | 4 | | 294 | Using where |
FROM xf_thread
LIMIT 5
Run Time: 0.035597
SELECT thread.*
Params: 88436
Run Time: 0.000249
Params: 10
Run Time: 0.000375
SELECT thread.*
Params: 88436
Run Time: 0.000281
Params: 10
Run Time: 0.000352
INSERT INTO `xf_session` (`session_id`, `session_data`, `expiry_date`) VALUES (?, ?, ?)
Params: 64ca0362e238dd6ed9069839ebef7b1d, , 1611132651
Run Time: 0.031171
INSERT INTO xf_session_activity
(user_id, unique_key, ip, controller_name, controller_action, view_state, params, view_date, robot_key)
VALUES
ON DUPLICATE KEY UPDATE
ip = VALUES(ip),
controller_name = VALUES(controller_name),
controller_action = VALUES(controller_action),
view_state = VALUES(view_state),
params = VALUES(params),
view_date = VALUES(view_date),
robot_key = VALUES(robot_key)
Params: 0, , , XenForo_ControllerPublic_Thread, Index, valid, thread_id=88436, 1611129051,
Run Time: 0.000165
SELECT data_value
WHERE data_key = ?
Params: uix_nodeCache
Run Time: 0.000251
SIMPLE | | | | | | | | Impossible WHERE noticed after reading const tables |
SELECT *
FROM uix_node_layout
Run Time: 0.000233
SIMPLE | uix_node_layout | ALL | | | | | 2 | |
SELECT data_value
WHERE data_key = ?
Run Time: 0.000213
SELECT node.*,
node_field.uix_node_icons,
node_field.uix_styling,
node_field.collapsed,
node_field.inheritClass,
node_field.inheritStyling
FROM xf_node AS node
LEFT JOIN uix_node_fields AS node_field ON (node.node_id = node_field.node_id)
Run Time: 0.000574
SIMPLE | node | ALL | | | | | 37 | |
SIMPLE | node_field | eq_ref | PRIMARY | PRIMARY | 4 | terrylove_xenforo.node.node_id | 1 | |
SELECT title, template_compiled
FROM xf_template_compiled
WHERE title IN ('page_nav', 'bb_code_tag_code', 'bb_code_tag_php', 'bb_code_tag_html', 'bb_code_tag_quote', 'bb_code_tag_attach', 'bb_code_tag_spoiler', 'thread_view', 'resources_tab_links', 'PAGE_CONTAINER')
AND style_id = ?
AND language_id = ?
Params: 7, 1
Run Time: 0.000647
SIMPLE | xf_template_compiled | range | PRIMARY | PRIMARY | 60 | | 10 | Using where |
