Updating old irrigation - sprinkler pump pressure and drip tubing question
patryk
FL
Hi, I’m renovating my yard and reworking the irrigation layout. While tracing the system, I found multiple burst lines, and the existing piping was a complete mess which it took me weeks to map everything out. I also discovered that some PVC pipes cracked at the couplings, though I’m not sure why. I had to spend time on filling any small sinkholes under concrete walkways caused by those leaks...
The old setup had garden beds and lawn sprinklers mixed in the same zones, so I’m now separating them into dedicated zones and expanding the system. My irrigation draws water from a cana via a dry sprinkler pump. I also recently purchased a Hunter Hydrawise controller. For the garden beds, I’m using ½" poly tubing for drip irrigation.
I have a few questions about the best setup:
1. Should I run PVC along all garden bed zones and connect the drip tubing to the PVC on both ends to make a closed loop or is there a better approach? Or maybe use PVC just to reach each zone and go with poly from there with a closed end?
2. Would it be better to lay ½" drip tubing in a straight line along the shrubs with drippers or use ¼" tubing connected to the ½" poly to reach each shrub? I’m concerned about additional failure points with the ¼" tubing.
3. Should I add a pressure regulator? If so, should it be installed on the main line or after each zone valve?
4. Since I’ll be using drip irrigation, what type of filter would you recommend to prevent clogging?
5. Based on my setup, would you change anything in my zone design?
I've attached two pictures showing the layout. The first one is how I'm planning to do the zones. And the second one shows the sprinklers - blue lines is the drip tubing, orange is sprinkler heads, red is valves and pump, green is plants.
