Adding Disposal to Double Sink without Baffle Tee?
CliffA
Massachusetts
Is there a way to add a disposal to a double sink without using a baffle tee, and still meet code?
For example, can I give both the disposal and their other sink their own trap, and put a Wye on the arm? Does that run afoul of the two trap prohibition even thought the traps are in parallel?
Or can I take the outlet of the disposal over to the other sink, as is usually done, except use a sweep tee instead of the baffle tee?
One slight complication. I need to put the disposal on the left sink. The vent is to the left of the sink because of a window. So right now the arm goes to the left sink, which is closest. But if I need to, I can use a 45 degree elbow to point the arm to the right sink.
