I am channeling for above counter outlets in a kitchen remodel in a 1940 home and accidentally cut into the wall of the iron vent pipe from my kitchen sink. It's 1 1/2 inch galvanized pipe and embedded in the brickwork of the exterior walls. I probably cut a bit less than 1/16 inch and not through to the inside of the pipe. To what degree do I need to be concerned? Can it be repaired superficially or will it rust though at the nicks and cause a problem later?
A secondary concern: the setup has two drain lines oriented vertically. My intention is to cut through the vent above the highest drain outlet and run the rest of the line in ABS to sewer. The vent line makes a 90 degree turn right above the drain inlets and runs horizontal below a window opening for about 3 feet before turning 90 degrees again to run through a wall to the roof line. The kitchen sink I removed was draining through the lower inlet and the upper inlet was capped off. When I took the cap off of the upper drain stub, it was packed full of rusty debris and small roaches. After seeing that I'm concerned it might be best to replace the horizontal run of vent but I'd rather not get into that much demolition unless it's absolutely necessary. Suggestions? First the dealing with the accident and then the discovery of the disused drain stub full of crap.
See attached images below:
