David Isom
Hi again ...
I have recently installed the above with .88cu ft resin (25 litres) I am in Europe. it’s going very well and prior to first regen have been testing water daily to get an idea of how much water the unit can soften at maximum capacity. What I have noticed is that the counters in the unit are way off from my utilities water meter . I have today made a manual check and it seems that if water is run continuously the counter is pretty accurate. However if you draw just a little water at a time then the counter adds Up much more quickly. As an example I have used around 3800 litres less than 1000 us gallons but the totalizar on the 5800 tells me that is registers 6000 litres of water used that’s over 1550 gallons I.e over by more than 50%. Can’t think why it’s so bad at counting water flowing through. Any comments much appreciated to what’s going on ?
on this basis I will have to do a manual regen every time !
I have checked programming and it says .75 turbine. Is there any way I can check exactly what is fitted ?
David
David
