Rechrgd
My well was drilled in the early ‘80’s. I was thinking about getting a hand pump for an emergency water source if needed. When measuring where the static level was sitting and shining a light down the well, I noticed what appeared to be 5” pvc pushed into the 6” steel casing that comes to the surface. I thought it was 6” all the way down its 350’ depth. Not sure if I could install the hand pump piping now. I would need to snake a flexible pipe and foot valve down to at least 100’. Is or was 5” casing a standard practice?
