4 wire well pump, control box, and pressure switch wiring help
Keith5486
Elberton, GA
Working on rehabbing and old well. Its 88ft deep. I've purchased a deep well submersible pump. It runs on 110v. I need help wiring it. It comes with a control box. And obviously i need to wire in a pressure switch. I'm a bit confused as the pump is a 4 wire pump.
What goes where?
There are at least 3 points of view. Some will run the hot and neutral from the breaker to terminals 1 and 4 on the pressure switch.
Some will only switch the hot running the hot line to either terminal 1 or 4.
And some will only switch the hot, but will parallel the contacts.
After the pressure switch, follow the instructions that came with your control box.
