3 gang Insteon switch install driving me nuts~
Discussion in 'Electrical Forum discussion & Blog' started by frodiggs, Jan 17, 2016.
  1. frodiggs
    frodiggs New Member
    Apr 29, 2014
    NJ
    Going a bit nuts here and my lack of experience is getting in the way.
    Replacing 3 switches - 2 older 2 wire Leutron dimmers and a leutron 3 wire dimmer [which is also controlled at the other end of the kitchen. This 3 way switch has contrasting orientation.]
    new switches are Insteon home automation type dimmers (2477D). The Insteon's have red/white (load) black(line) and bare copper ground wires.
    I was able to get the 3 way working (far right) but having problems integrating the other 3 wire Insteons to the existing 2 wire setup that the leutrons had.
    See pic. The other 2 standard 2 wire dimmers we're just pigtailed to a line and separately to loads, seems i've not completed the circuit.
    My 2nd new switch (1st on left) has power but will not control light, ive not integrated the 3rd new switch yet- old leutron in in the middle
    [​IMG]
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    When I walk into a job like this, the first thing I do is ignore what the owner did and start over from scratch.
    1. Identify the hot and neutral coming into the box.
    Never assume there is only one hot coming in.
    2. Identify which cable feeds which light.
    3. For a 2-way switch identify which is the hot and runner conductor separately.
    A basic 2-terminal switch is line and load + ground,
    A lighted or "smart" dimmer will often require a neutral.
    If you don't have a multimeter and know how to use it, leave the electrical work for those that do.
  4. jadnashua
    At the switch, it is fairly common on not very old construction for there to NOT be a neutral available (latest codes I've heard require it, making the wire routing a bit less efficient in some cases). Some of the smarter automation switches require power and neutral, and you can't get there without rewiring where an 'old-school' dimmer would have worked just fine. The switched leg should have a red marker on it, but that often is not done.
  5. jadnashua
  6. frodiggs
    frodiggs New Member
    Apr 29, 2014
    NJ
    I have Klein tools ET50.
    6, 2 wire cables in the box
    original setup
    all ground wires spliced together
    wire cables 1&2: whites are netural and spliced, blacks are spliced and are line. the original dimmers were pigtailed to this spliced black line to their line wires
    wire cables 3&4: whites are netural and spliced along with neutral from cables 1&2, blacks are load and independently went to the 2 wired dimmers as load
    wire cable 5: white is netural and spliced along with neutral from cables 1-4, black is load went to red wire of old dimmer [and now connected to red wire of new dimmer]
    wire cable 6: white is oddly line here and is connected to black wire on new dimmer. black wire not used currently
    working new dimmer on far right also has neural added to 5 spliced neutral wires and ground wire connected to spliced grounds.
  7. frodiggs
    frodiggs New Member
    Apr 29, 2014
    NJ
    go it working with this setup
    Black 1, black 2, dimmer 1 black, dimmer 2 black all get connected together.
    Black 3 goes to dimmer 1 red.
    Black 4 goes to dimmer 2 red.
    Whites get connected to the neutral splice.
Similar Threads: gang Insteon
Electrical Forum discussion & Blog Replacing a 2-gang switch with a 3-gang switch Jan 5, 2019
Electrical Forum discussion & Blog Does ANYONE make a switch with MULTIPLE DIMMERS in 1 gang, for LEDs and 3 ways in decora/rocker?? Nov 8, 2015
Electrical Forum discussion & Blog 1 circuit/2 gang 3 way switches- Does this look right? Apr 17, 2014
Electrical Forum discussion & Blog 12/4 to run constant and switched receptacles in 2 gang boxes Apr 2, 2014
Electrical Forum discussion & Blog Using grounding bar inside 3-gang metal outlet box Mar 14, 2014
