plumbud
Hello, I have a weil Mclain series 10 CGM boiler, 27 years old apparently. Still runs really well. It heats three zones, I have a one story home, pressure is a constant reliable 15 psi and the boiler heats well, one day I noticed the boiler relay humming extra loudly and wouldn't turn off. I isolated the loud buzzing one one specific zone, if i disabled this zone the other two zones performed perfectly boiler turns on, sends heat turns off when finished, the one zone in question, the relay buzzes, the boiler heats, but the zone does not get hot, relay buzzes and stays on as the thermostat is calling for heat, when i feel the pipes the section for this zone around the boiler gets quite hot, but the return pipe stays fairly cool, the circulator gets extremely hot, but just beyond the circulator doesn't get very hot past say, 4 feet. i'm not getting any noise from the circulator the other two circulators you can hear them humming, i'm not sure whether my circulator is the issue or if my relay is going bad. I've just purged the system 15 minutes a piece, and double checked to make sure i didn't see any air. Any advice is really appreciated, thanks so much for reading.
