Weil McLain not staying lit
motoguy
I have an older Weil McLain natural gas boiler heating hot water radiators. It is a CGM-6-PI Series 8 (CP1453423). Back in 2015 I had to replace the gas valve for a no-start issue. It was fine until, January this year. I was losing heat in the middle of the night. Pilot would light, then burners would ignite, and after a second or two shut down. Flame height and intensity were what they should be. I tested a bad relay so I replaced the transformer/relay panel. This lasted for three months until I started having a very similar problem this week. Same symptoms except when I remove the front cover and the smaller access panel (that rests on the burners) the burners stay lit. If I restore the access panel and front cover, the burners will stay lit until they cycle off when the thermostat reaches temperature. The next time there is a call for heat I get the same start up and immediate shut down.
What am I missing? If the relay is bad again, would removing the access panel effect ignition? I am using two identical Honeywell smart thermostats. No strange noises when the call for heat comes down and the pilot/burners ignite. Circulator pumps keep running with the call for heat even after the pilot/burners shut down (and no heat has been provided).
John Gayewski
Iowa
Can you take a picture with the cover off? I had a similar problem recently.
Fitter30
Peace valley missouri
Take a pic od the burners before starting.Pull the burners and pilot assembly. Turn burners up knock the dirt out of them. If you have air compressor blow them out outside in or use water. Pilot shine a light inspect the orifice. Its a small hole. Thermocouple can have a longer wire if one isn't available the same length.
