Thanks ahead for the help.
Here is the situation. Complete shower redo. I installed standard shower faucet on front wall and a handheld shower with drop el on side wall next to bench. Plumbed each separate and bought a 2 way diverter. The plan was to be able to stop flow from standard shower on front wall and divert it to the handheld shower on side wall for wife and kids.
I thought I tested the diverter prior to tiling but now I don't know if I did.
The problem: When I turn the shower water on, water flows to both the front wall and side wall shower heads. When I turn the diverter, water is diverted to the side wall handheld like planed. However, there is no way to isolate front from side. If I only want the front shower head on, I can't. Both stay on. I can only use the side by itself.
I guess I screwed up the plumbing lines or bought the wrong diverter.
Possible Fixes?
Can I buy a shower stop valve and install on the drop el. This way if I only want to use the front shower head I turn the stop valve off to the handheld. From what I've read, these valves are not 100% stop. So water will leak from side shower head.
or
Do I remove 2-3 tiles on front wall and replumb? or cut an access panel to wall behind plumbing?
Thanks for your help. At this point, I completely exhausted from this 6 month project. Trying to get this bathroom project done with a full time job and 3 kids is nearly impossible. I appreciate any comments.
Possible Fixes?
or
