Brad Perkins
I am building a house and had a well drilled but unfortunately ended up with nearly a dry hole... 1 gpm. They went to 180 ft hoping to hit a better vein when I told the guys to stop. So I have around 200 gallons of storage as it sits. They told me I should have enough water for the house but I'm skeptical. Fortunately I have rural water at the road but I have to trench it 1500 ft to the house. Was hoping to drill a good well near the house to avoid the hassle and monthly utility. So now I have a well without a pump that I'd like to use for irrigation instead.
What size pump would I need for this? Do I still need a pressure tank?
My thought was maybe a sprinkler system but I'd be ok for now moving a sprinkler around by hand. My main concern of course is running the well dry and harming the pump. I'd also like to hook up a couple hydrants to water trees. I see a potential disaster there turning on the pump with the hydrant off and burning it up. I think a pressure tank would prevent that problem... But I'd rather not have a pressure tank if there is a way around it. Thoughts?
