I've been doing some reading and the water isn't quite so muddy anymore but still have a couple questions.
Would I need a dole valve to slow the rate of flow to the cistern to help project the well pump from cycling or would it be ok with a 7 gpm pump since it would run about 25-30 min with a full well? Then a cycle sensor would protect the pump from running dry correct? Now does that cycle sensor have a feature that commands it to not power the pump again for say 3 hours once a dry condition is detected?
Now I'm still unclear how I can get water pressure to outside hydrants. With a float sensor triggering the well pump and a PK1A setup triggering the cistern pump, I'd have to T off the PK1A and run another pipe outside but I don't really want to drill 2 holes in my basement wall. Now in another diagram I see 2 PK1As in the system.. 1 before and 1 after the cistern. What has me confused is why I couldn't T off between the 1st PK1A and the well pump outside so that I only need 1 pipe going in my basement. See pic
