Gene Bryant
After a 5 month gut and remodel of a 1970 fishing cabin we are putting things back together after complete overhaul of plumbing except for cast iron vent which I left (although I broke the lavatory drain/vent into the pipe and had to come up with another way) -- I went to put new toilet in today and noticed my toilet flange was turned where the normal place to put closet bolts did not align -- I can put them in one of the cutouts (the toilet supply line in the picture is comes out parallel to where closet bolt goes --- I question that though, afraid over time it might work it's way out of the side of the flange -- thought about maybe tomorrow running by box store and getting a flange repair ring, put the closet bolt in ring and then put it under the indention of the old flange -- that way it can't come out side ways ---- guessing these cutouts/indentions are where you can screw the flange down to wood subfloor?
I noticed when I pulled out floor and toilet it had screws toward front of toilet into subfloor - first time I had seen that - but going back with new toilet.
Maybe it would be ok to just put them into that indention and tighten down with nut on flange?
Also, when I sat toilet I did not get a mashing wax down like I have in past, and when I pulled toilet, the wax ring was stuck to bottom of toilet, but it wasn't mashed much if at all. Flange is sitting on subfloor and went with vinyl planks that are about 1/8th of inch so it appears the finished floor is close to bottom of flange - maybe I should go with one of the bigger wax rings + the repair ring might bring it up a hair?
I am a not a builder nor plumber - we've just done it all because it is so far out we've not had a lot of luck getting anyone to come that far.
Here is a picture of the flange - seems to look pretty decent for 1970 -- I would not know how to get it off to replace - wanted to replace all that cast iron, but afraid it is above my skill level.
EDIT: wondering about going with something like this (new picture/mounting screws) and screwing into subfloor? I bet that is how they had the original mounted and I just did not notice it when I tore floor out
