Skip Wolverton
Looks GREAT. I know you will enjoy clean water. Congrads.
You're welcome and yes you're right, a huge difference but no I can't tell you where the SS wraps are made. But one of the largest and oldest SS softener/filter tank manufacturers is in Mechanicsburg PA. The owner's name is John, his son's name is Rob and if you want contact info, email me your email address.Thanks for pointing that out to everyone. I'm sure it makes a huge difference. Could you tell us the grade and thickness of the stainless while you are at it? Perhaps the country and factory it was manufactured in. LOL
New resin comes pre-charged. No need to increase the salt for the first regen.Thanks guys. Even though it's just an insulating jacket, the SS does look nice.
I'm paronaoid about potential leaks so I'll force a regen tonight after everyone goes to sleep. Is there any reason to do the first regeneration on a higher salt setting? Or is it fine to leave it on the 3.3lbs/cuft that I'm going to keep it on?
For real? I had no idea
p.s. SS tanks don't have the black plastic cap on them.
I know.Reaally? I had no idea
Originally Posted by Gary Slusser You're welcome and yes you're right, a huge difference but no I can't tell you where the SS wraps are made. But one of the largest and oldest SS softener/filter tank manufacturers is in Mechanicsburg PA. The owner's name is John, his son's name is Rob and if you want contact info, email me your email address.
I know.
But I see you are improving in your attempt to learn how to quote and I suspect that with more practice you'll know how shortly.
There ya go!, ya got it now.You are the champ baby
All control valves come from the factory with default settings. The dealer/installer is supposed to input the hardness in gpg, the K of capacity and the salt dose lbs or volume of refill water either in the control valve or the or volume of refill water in the salt tank with a float.Gary; "K" is controlled by the salt per regeneration? I was always taught that is was controlled by the amount of resin in the tank and THAT controlled the amount of salt needed per regeneration. I guess that means all those electronic meters that are programmed according to the water hardness so the softener knows when to regenerate, should be reprogrammed according to the amount of salt being used.
Gary,
Using your 20k/6lbs salt math, don't you have to add in the reserve? I was taught you factor in a 20% reserve. So you are using 16k and not 20k. This is why I use 20K/8lbs salt.
And here there is a 3.0 cuft at did he say 3 lbs?
According to the manual, the Autotrol 768 has 3 salt does settings, 3lbs/cuf, 9lbs/cuft, 15lbs/cuft. They call the 3lbs/cuft the "high efficiency mode". With 3 cuft of resin that gives you capacities of 44k, 75k, and 90k respectively. When I enter in 12gpg hardness it calculates how many gallons available before regen (~3,600gals). Since we are currently using <200gals per day, I set the calendar override at 14days, rather than waiting up to 18 days for the meter to say a regen is necessary.
