what are some tricks to tighten chrome/nickel etc pipes
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbillcee, Feb 20, 2011.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    i see some guys use a pipe wrench close to the wall behind finish plates, duct tape around the pipe, what do u pro's do?
  2. Terry
    Aug 17, 2004
    If it's a shower head, I attach the shower head, and then I can hand turn it,
    I can hand turn tub spouts, I Have never needed anything else.
    And shutoff valves normally have flat sides on them for a smooth jaw wrench.
    Most plumbers are strong enough to do most of these things without tools, therefore saving the finish on your fittings.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Never used duck tape but have used electrical tape. Sometimes I use a rubber strap wrench. On something like a tub spout, I may put a screwdriver handle or wood dowel in the outlet for extra leverage. On something like a wall union, I will use an allen key of the right size in the outlet to get leverage.
  5. hj
    Unless you use a strap wrench and rosin, there is almost no way to prevent wrench marks on finished surfaces. Usually, I tighten a nipple by turning the fitting on the other end of it.
  6. Ian Gills
    Jul 24, 2007
    USA
    I have had some success padding the surface with an old rag, then gripping and turning.
  7. hj
    pipe
    When you wrap a pipe with anything before tightening it, the force you apply is limited to whatever the material will hold until it starts to slip, and that may NOt be enough to prevent leaking.
  8. Beantown Plumber
    Beantown Plumber Business owner, Plumbing Tech.
    Feb 21, 2011
    Boston, Massachusetts
    I have a set of internal pipe wrenches that I use all the time. Theese things are very handy, and perfect for chrome. They leave no marks at all because they bite on the inside.
  9. ballvalve
    Dec 28, 2009
    northfork, california
    Piece of slit heavy hose clipped over the pipe and channel locks.
  10. ilya
    ilya In the Trades
    Dec 10, 2009
    home repair -I am not licensed and never represent
    Akron Ohio
    Beantown, I love internal wrenches but can't find good ones that last. Got a good brand name for me? Thanks!
Similar Threads: tricks tighten
Plumbing Forum, Professional & DIY Advice Any tips/tricks on tightening flange bolts? Mar 2, 2014
Plumbing Forum, Professional & DIY Advice Sweat soldering tips/tricks Dec 22, 2016
Plumbing Forum, Professional & DIY Advice Tricks to increase work time with ABS glue? Mar 5, 2016
Plumbing Forum, Professional & DIY Advice Any hints/tips/tricks to closing a "stuck" quarter turn ball valve? Feb 10, 2016
Plumbing Forum, Professional & DIY Advice Tricks to clear rusty floor drain trap Dec 4, 2015
