Venting question
Jwill
Salt Lake City, UT
See attached picture below...
I'm currently working on a basement renovation. As part of that, we ripped out an old bathroom and are re-doing it. We busted up the concrete and laid new ABS piping for the toilet and shower. I need to still add the vanity drain connection. I also wanted to add a sink to the opposing wall which happens to be the laundry room. Is the venting situation correct for what I am trying to do? I know the yellow part would be considered a wet vent but not sure if that would be a big deal or not. Or do I need to run vent lines from each
1. Is adding two sinks this way okay?
2. Is venting this way okay or do I need to run vent lines up from each sink drain run?
Blue pipe = what is currently run and approved by inspector
Yellow shading = wet vent ??
Green = proper vent (at least I think so) ??
Thanks in advance for all you help!!!
- Jon
The yellow pipe is a drain, not a "wet vent" and the shower is NOT vented. The green horizontal line is also not a proper vent. The type of fitting you used for the two sinks might also be improper depending on what it is.
Jwill
Salt Lake City, UT
Thanks. Even if I don't do the laundry sink, it still wouldn't be right? I wish the inspector would have told me that before he passed it and before I put the concrete back. That is going to be an awkward conversation when he comes back for the 4 way rough in. Hmm, now I'm not sure what to do.
If it has already been inspected and passed, then it is probably NOT going to be an issue. What COULD be an issue is the size of the pipe you are using for the drain. If it is 2" it will be okay, IF you use the correct "4 way connection". If it is 1 1/2" it will not work and you won't find the correct fitting in that size anyway.
Jwill
Salt Lake City, UT
Thanks, I'm hoping it will be okay. I checked it again this morning and it is a 2" drain pipe coming up from the floor. I'm assuming that the correct 4-way connection you are talking about is a double sanitary tee? Thanks again for taking the time to respond.
