Use tub outlet of valve for shower?
Kristi
Tradesman Plumber
Vancouver, BC
www.prettyplumbing.com
Hi guys,
I haven't done this one before: do you foresee any issues with using the tub outlet of the valve for the main shower head and then the shower outlet for the secondary rain shower head? Purpose being to divert between one head or the other... ?
I don't see why this wouldn't work as long as diverters were added.
The tub outlet is less restricted, most shower valves will run up to three heads.
shower
using the tub outlet for the main shower head will create sufficient back pressure that both heads would work at the same time until the diverter was operated to allow just the secondary one to have flow.
Kristi
Tradesman Plumber
Vancouver, BC
ohhh... that would be a bummer. This is a pretty high end bathroom the client is building, and I want to make sure this works properly. What would you suggest to avoid the back pressure forcing water through the overhead rainshower head? It drops from the ceiling, there's about 7' of 1/2" copper between valve and head...
Thanks alot Terry and HJ, I appreciate your help :)
Jimbo
San Diego, CA
If you go to a good plumbing house, or even the design desk at the HD, they have manufacturers catalogs with diagrams of how to plumb these types of systems. If the proper techniques ( i..e. loops and pipe sizing ) are followed, and you select appropriate valves , this will work very well. Short cuts and "jury-rigging" the wrong parts can lead to a headache.
Lakee911
I&C Engineer (mostly WWTP)
Columbus, OH
Kristi said:
...the overhead rainshower head? It drops from the ceiling, there's about 7' of 1/2" copper between valve and head...
Going to but in one issue.... I did this in my last bathroom remodel. It's nice. :) I only used one showerhead though and its the rainfall. I'm going to install a heated pipe tracer in the attic to keep the pipe up there from freezing since it doesn't completely drain out. It might not freeze, but an once of prevention helps you sleep at night. I'd hate for the girlfriend to turn on the shower in January and have it start raining from all the light fixtures upstairs!
Jason
Kristi
Tradesman Plumber
Vancouver, BC
Don't have to worry about freezing, as we're in Vancouver, BC (the mildest climate in Canada) and the client (and their shower) is in a condo with a floor above.
HD and my wholesaler won't be much help, as the client purchased the valve and heads directly from Switzerland... it took us 2 months just to figure out if they were approved for the inspection or not! I do have a bit of a loop happening before the 7 or so feet of pipe to the head, so hopefully that will facillitate most of the pressure for the "tub"??? Wondering now if I should have upped the pipe size to the head...
Thanks guys,
Kristi
shower
The pressure is generated by the distance above the valve, and larger pipes, distance, loops, and/or anything cannot change that. The only solution is a multiport diverter valve, but you would either have to get it from the original manufacturer so its handle matched the shower valve, or find a domestic one that has a similar appearance.
