Tub Spout Occasionally Discharges Water
Discussion in 'Shower & Bathtub Forum & Blog' started by jessieg, Jun 25, 2014.
  1. jessieg
    jessieg New Member
    Jun 25, 2014
    wa
    In a recent remodel, I had a two handle wall-mount Newport Brass faucet set with a 1-500 valve installed. This is a tub only, no shower. The new install was approximately 8" from the old tub, requiring the supply lines and drain to be moved. The plumber used Zurn pex supply lines tied into the existing water lines, which come in from the side. Water seems to build up and suddenly dump out of the spout for no apparent reason after using the faucet. Originally I thought flushing the toilet or running the sink faucet caused it to release the water, but yesterday it happened 11 hours after using the tub. It is a sudden discharge of about 1-2 cups of water. I asked the plumber if the valve was installed upside down and he said it wasn't, but that it wouldn't cause it if it was. The hot and cold cartridges were reversed when installed, but I was told the only thing that would affect would be the direction the faucet handles turn. Manufacturer has no idea and plumber has no clue what is causing it. It probably isn't a big deal, but it is a puzzle that is driving me crazy. This was an expensive faucet and a costly, but rather straightforward installation. It should work correctly. Any ideas?
  2. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
    Looking at the valve body -it's long and tublar - could it be that the water doesn't drain out because of suction? Then after a while the vacuum breaks?
  4. jessieg
    jessieg New Member
    Jun 25, 2014
    wa
    My plumber offered a similar suggestion. Seems the manufacturer would be very familiar with the issue if this was the case.
  5. Terry
    Aug 17, 2004
    My guess too.
  6. jadnashua
    You can get a similar situation with a showerhead...in some cases, it can take 20-minutes or more before you can be reliably assured it won't drip any more. Because the spout is bigger verses lots of smaller jets, it is more likely to happen sooner rather than later, but like putting your finger over the end of a straw...it can hold water in the tube.
Similar Threads: Spout Occasionally
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog Tub Spout Plumbing Jan 14, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Is this Grohe leaky tub spout diverter repairable?? Jan 2, 2017
