sametime
Toilet is a Crane Galaxy/Cranada (? No idea the actual model) judging by a picture guide and is around 12 years old.
https://www.plumbingsupply.com/cranetoiletparts-galaxy-cranada.html
I'm in the process of replacing the toilet tank bolts as one of the heads has snapped off. (As an aside, what's the pros/cons to using a Wing Nut vs. Hex Nut at the bottom of the bolt against the toilet bowl?)
I'm wondering if I should also replace the tank to bowl gasket at the same time?
If so I'm also having some difficulties understanding the sizing. The above site lists the following measurements - 3-1/2" O.D. x 2" I.D. x 1-1/8" high
but it doesn't correspond at all to the measurements I'm taking. Although I don't know how much that has to do with the gasket having been squeezed and compressed.
I'm measuring 9.7cm (3 13/16 inches) O.D , 5.7cm (2 1/4 inch) I.D , 2.2 cm ( 55/64 inches) high (only have a Canadian metric ruler, doing the conversion manually). This is with the gasket not removed and still on the tank however.
The Korky Universal Kit seems to be - 2-1/8 inch inner diameter, 3-1/2 inch outer diameter and 1-1/4 inch thick
The Fluidmaster one doesn't seem to list the measurements.
While I've also found this which says it's for Crane toilets - https://www.lowes.ca/product/toilet...kit-bolts-and-gasket-for-crane-toilets-191521
which has the following measurements -
- 3-3/16-in x 2-1/8-in x 1-3/16-in sponge rubber gasket
