I have two toilets to replace and have decided to use the Vespin II and/or the Drake II. My problem is the supply lines come through the cement floor and I can’t determine if the lines will clear the toilet bowel. On the first toilet, the line is 6in to the left of the drain centerline and 8in up on the wall. It is a 10 ½ in rough-in so I will need to use the Vespin II with a 10 in kit. If it will fit. That is if the Supply line will clear the back of the Vespin bowl. I hope someone can help with my problem.
The other toilet has the supply line that comes up through the cement floor. It is offset by 8in to the left from the centerline of the drain and 6in from the wall. Would this clear the Vespin II or the Drake II? The rough-in is 14 in, so I could use the 12 in or 14in kit on the Vespin II if that would give enough room. I am open to the using the Drake II on this if needed.
One more thing, the house was built in 1993 so it is plumbed with the gray poly pipe; I think it referred to as PB. This could be a problem with causing a leak.
