Shower valve with male thread
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dougeefresh, Sep 19, 2012.
  1. dougeefresh
    dougeefresh New Member
    Sep 19, 2012
    Chicago
    Hello.
    I just bought a shower valve from Price Pfister and it has male threaded ends.
    Is it OK to just sweat the copper tubes on directly or should I go through female threaded ends? Any reason not to solder on the tube directly on the male end? Thanks!
    Great forum by the way!
  2. Terry
    Aug 17, 2004
    If you can insert the copper there, then that's the second option you have. I would solder the pipe and skip the fittings.
  4. dougeefresh
    Sep 19, 2012
    Chicago
    It fits well just like any others without the threads so I will solder them on.
    That was an awesomely quick response. Thanks, Terry!
  5. hj
    That is the way a plumber would do it. But, it is INTO the threaded end, NOT ON it.
  6. dougeefresh
    Sep 19, 2012
    Chicago
    Hi, hj,
    Yes, that's what I did and it worked like a charm.
Similar Threads: Shower valve
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Moen Shower Valve is stiff. Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Replacement Shower Valve Jan 2, 2017
