Shower drips while tub runs
Discussion in 'Shower & Bathtub Forum & Blog' started by eastert, Nov 20, 2009.
  1. eastert
    eastert New Member
    Jul 25, 2009
    I installed a new tub fixture. It is the two handle type with 1/2 inch copper going up to the shower and 1/2 copper going down and over to the tub spout. When I run the tub, water drips out of the shower. What might be the problem?
  2. hj
    valve
    Normally the only thing that causes that symptom when you have used copper down to the tub spout is that the valve is installed upside down.
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    When you say you ran the tub spout down and over are you saying it's not just under the valve? If so this may be your problem. If you have to many fittings between the valve and the spout the added restriction is forcing some water to the shower head.
    John
  5. hj
    spout
    I assume he meant "down and out" rather than "down and over, (and then out)".
  6. eastert
    eastert New Member
    Jul 25, 2009
    To clarify: I ran copper down and out. There is only one 90 degree fitting between the valve and the tub spout.
  7. Terry
    Aug 17, 2004
    Can you post a picture of the valve.
    The side toward the shower is a reduced size, forcing water to the tub first.
    If the valve is upsidedown, then some water will be forced up to the shower head.
  8. jadnashua
    Some valves don't want you to use both outputs...they want a twin-el if you need both, then cap the other valve outlet. What does the instruction sheet say? Does it say you can use both?
  9. hj
    valves
    Those valves do not have the shower restrictor and are usually thermostatic valves, such a Grohe. But if they were installed improperly, it would be a "gush/flood" from the shower head, not a drip.
Similar Threads: Shower drips
Shower & Bathtub Forum & Blog Diverter Spout Drips While Using Shower Head Oct 20, 2015
Shower & Bathtub Forum & Blog Stems replaced, shower still drips. Old American Standard stems. Feb 2, 2012
Shower & Bathtub Forum & Blog New tub/shower trim and valve...now tub spout only drips... Nov 22, 2010
Shower & Bathtub Forum & Blog Shower head drips, even with diverter open Sep 13, 2008
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Monday at 11:17 AM
