trchamberlain
I am working on a couple of shower drains in Honduras. They are in new construction but the concrete is already poured and the tiles laid right up to to top of the pipe. I know I can chip out the concrete but the pipes go horizontal just a couple inches under the surface. The first one is supposed to get the large square drain in pic 1. My first question is how do I adapt that down to the 2" drain pipe, especially with only a couple inches or less to make the transition? Do I just make a cement taper down to the pipe and cement the drain in over it? The screws in the drain are for the drain screen/stopper not for securing to the floor.
The second drain is supposed to take one of the two round drains shown in pic 4. How does this style drain work? Do I just slide it into the drain pipe and cement/grout around it? This one is also very shallow, can I just cut the lip shorter on the drain to get it down to the level of the tile?
Feel free to add anything you see from the pics I can use all the help I can get!
