Shower drains in Honduras
Discussion in 'Shower & Bathtub Forum & Blog' started by trchamberlain, Feb 21, 2014.
  1. trchamberlain
    trchamberlain New Member
    Feb 20, 2014
    Honduras
    I am working on a couple of shower drains in Honduras. They are in new construction but the concrete is already poured and the tiles laid right up to to top of the pipe. I know I can chip out the concrete but the pipes go horizontal just a couple inches under the surface. The first one is supposed to get the large square drain in pic 1. My first question is how do I adapt that down to the 2" drain pipe, especially with only a couple inches or less to make the transition? Do I just make a cement taper down to the pipe and cement the drain in over it? The screws in the drain are for the drain screen/stopper not for securing to the floor.
    The second drain is supposed to take one of the two round drains shown in pic 4. How does this style drain work? Do I just slide it into the drain pipe and cement/grout around it? This one is also very shallow, can I just cut the lip shorter on the drain to get it down to the level of the tile?
    Feel free to add anything you see from the pics I can use all the help I can get!
  2. trchamberlain
    Feb 20, 2014
    Honduras
  4. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  5. Terry
    Aug 17, 2004
    For starters;
    Does this shower have a p-trap below the drain to prevent sewer gas from entering the home?
    Is this a clamping shower drain that collects water from a vinyl liner?
    Or is this a 2" plastic 90 elbow embedded into mortar? That needs some sort of cover.
    [​IMG]
    A typical clamping shower drain. They make these in PVC too.
  6. trchamberlain
    Feb 20, 2014
    Honduras
    Thanks for all the help guys. I just got my instructions from a local guy who knows how it's done down here. This is going to make you all cringe but they just slide the bottom of the drain down the pipe and mortar it in. The square drain in the pics is only for 4" pipe so I didn't have to try to install that, thanks to God. You learn something new every day. It might not be right but it is new!
Similar Threads: Shower drains
Shower & Bathtub Forum & Blog Shower drain loud gurgling as it drains.... Jul 9, 2015
Shower & Bathtub Forum & Blog Curved Shower Drains: Installation Photos Sep 28, 2014
Shower & Bathtub Forum & Blog Testing Shower Drains for Compatibility with Wheelchair Use Nov 24, 2013
Shower & Bathtub Forum & Blog Brown ooze in shower pipes and drains Aug 5, 2012
Shower & Bathtub Forum & Blog Shower drains slowly Sep 24, 2010
