Shower Diverter Issue
Discussion in 'Shower & Bathtub Forum & Blog' started by wilsonrandy, Nov 8, 2009.
  1. wilsonrandy
    wilsonrandy New Member
    Nov 8, 2009
    Tennessee
    I have a 3-handle tub/shower that was leaking. I decided to replace the hardware for all 3 valves while I was at it. Luckily there was a kit available that included new seats, stems, handles, the whole nine yards. Everything went smoothly and the leak is now resolved. However, now when I turn the diverter handle to the shower position, only about 50% of the water is diverted. The rest of the flow continues from the tub spout. I've had this problem once years ago, but I can't recall what the fix was. I am baffled since everything from the seats outward is brand new.
  2. Terry
    Aug 17, 2004
  4. jimbo
    jimbo Plumber
    Typically, the diverter stem has a rubber washer at the hose ( this keeps water out of the shower when using tub) AND another gasket, often hard nylon, behind the nose. This stops water from going to the tub during shower. That washer may be missing, damaged at install, OR pieces of the original one may have broken off, and were unnoticed, and are still floating around the body. Remove the diverter stem and have a good looksee with a flashlight ....post some pics.
  5. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    fiber washer
    If the valve is like the one in Terry's picture and the old fiber washer (950-060) stuck inside when you took it apart, there are now two washers stacked up there. This won't let the diverter washer (950-040) bottom out and seal against the body of the valve. Try removing that fibre.
Similar Threads: Shower Diverter
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Yesterday at 7:02 PM
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Piping and a 3 way diverter in shower Nov 15, 2016
Shower & Bathtub Forum & Blog Help identifying shower diverter stem Sep 23, 2016
