Separate hot and cold water valves
Discussion in 'Shower & Bathtub Forum & Blog' started by bpap, Jan 3, 2013.
  1. bpap
    bpap New Member
    Apr 3, 2010
    MA
    Just a quick update and thanks to those that helped. Got the valve seat out with a #6 Easy Out as was recommended. The valve seat was about 50% corroded or broken apart. Now I need to see if I can find a replacement. The only identifying mark is on the escutcheon which indicate "Empire".
  2. Terry
    Aug 17, 2004
    Just so you know, most plumbers would have slammed in a new single handle and been done with it.
    But I guess you're getting close to having a working bath fixture.
  3. bpap
    bpap New Member
    Apr 3, 2010
    MA
    Yes. And I should clarify that I found a second plumber that actually got the seat out. I bought the #6 Easy Out and told him it had been suggested as a way to get it out. I am sure he was already was aware of that method. Anyway, he used that and my socket wrench extension to make it reach and had to put a lot of force into it to get the seat out (I had been very hesitant to put that much force on it as I was afraid I would just make things even worse than I had already made them).
    He had also suggested the single handle route but indicated a lot of people don't like to do that, and I am certainly one of them. The first plumber I had come out also suggested the single handle method and did not want to do anything other than that.
    Hopefully a replacement seat can be found. If so, I will have saved quite a few dollars, learned quite a bit, and have the separate hot and cold handles that I prefer. Apparently I may be one of the few people that prefers this though.
    Slowly making progress. Thanks again.
Similar Threads: Separate cold
Shower & Bathtub Forum & Blog Separate Hot & Cold Control For Shower May 2, 2016
Shower & Bathtub Forum & Blog No separate valves for shower? Jul 14, 2015
Shower & Bathtub Forum & Blog Shower move do I neet a separate vent for Shower? Jun 4, 2015
Shower & Bathtub Forum & Blog Mixing valve for shower and separate valve for bathtub Dec 5, 2014
Shower & Bathtub Forum & Blog Diverter or separate pipes? Apr 28, 2012
