Running a pump from a generator
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by tmartin, Apr 23, 2008.
  1. tmartin
    tmartin New Member
    Apr 23, 2008
    I have a 2hp irrigation pump set up for 230v. I want to use it to fill a water truck from a creek to fill stock tanks. Would there be any problems with running it off of a gas powered generator? What should I be concerned about?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    As long as the generator will start it, then it will run fine. Might start with a 3500 watt, may take a 5,000.
  4. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    When you start a big electric motor there is a short but large surge. The generator must be rated to handle that surge. The continuous load rating of the motor and generator can be the same, but the generator has to take the surge. This may mean a generator rating larger than otherwise needed for continuous use. Some generators are better about this than others. Check specs.
  5. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
    Isn't a two HP something like 1500 watts?
    We run pumps on generators all the time. Just make sure you have enough generator for the job and grounding protection in place.
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    1 HP equals 745.7 watts. But start up takes about 6 times that much.
  7. tmartin
    tmartin New Member
    Apr 23, 2008
    Thanks for the info.
    I believe it is a 6000 watt generator. It has a 230 outlet. It runs an electric jack hammer pretty well. I was trying to save some money by using an electric pump and a generator that I already had, but I think I will just buy a gas powered irrigation pump. I don't think I have room for both the pump and the generator on my truck. I think a two inch pump and a five horse engine should work good enough for filling a water tank. Thanks for all the input.
  8. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
Similar Threads: Running pump
Pumps and Tanks Well Forum & Blog. Water is life. Jet pump will not stop running after new switch installed Aug 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Circut Breaker Trips - Pump Wire Short, Bad Pressure Tank, or Well Running Out of Water? Jun 11, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump Running Not Building Pressure Above 20 Apr 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Running a submersible pump with a generator Feb 4, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Short cycling of well pump when no water is running Aug 2, 2015
