Riser Clamp Size
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DougB, Sep 30, 2013.
  1. DougB
    DougB Member
    Jun 19, 2010
    Software Developer / Engineer
    Minneapolis - Land of 10,000 taxes
    I want to cut out a section of cast iron waste pipe, and before doing so, install a riser clamp on the floor above.
    The pipe is 3 1/2" OD - I figure this is what they call 3" waste pipe?
    All I've been able to find on the net (and Grainger) are 3" riser clamps. What do you think?
  2. jadnashua
    I think, but do not know for certain, when they are referring to a 3" riser clamp, they're referencing the ID of the pipe...most of those I've seen are two parts that clamp around the pipe, and the OD has some leeway. Most drain pipe has about 1/4" walls, so 3.5" is about right for the OD.
  4. Terry
    Aug 17, 2004
    It would be a 3" riser clamp
  5. hj
    A 3" waste pipe would take a 3" pipe clamp.
  6. DougB
    DougB Member
    Jun 19, 2010
    Thanks guys.
Similar Threads: Riser Clamp
Plumbing Forum, Professional & DIY Advice riser clamps Jan 26, 2008
Plumbing Forum, Professional & DIY Advice riser clamp questions Dec 28, 2007
Plumbing Forum, Professional & DIY Advice Riser Clamps Oct 15, 2007
Plumbing Forum, Professional & DIY Advice Steel riser clamps for PVC Jun 1, 2007
Plumbing Forum, Professional & DIY Advice riser clamps... Jul 7, 2006
