connecting a wall-hung toilet to waste riser
personage
Illinois
Ended up going with Kohler. I'll be making a custom 4 x 3 90 that threads into the 4" waste riser and use a 3" rubber no hub coupling to connect to the elbow that comes with the carrier.
I have ordered K-18829-NA carrier, and the tank inlet valve uses G1/2 threads. It comes with a 1/2" NPT adapter. What is the preferred way of connecting copper line to it? Would you screw on and solder a female adapter, or should I use a union?
personage
Illinois
Ready to put in a new water supply line. Do I need a water hammer arrestor here? The existing supply had one, but it is now probably too far from the new inlet valve. Would you recommend that I install a T at the top of on the new vertical line and put a new arrestor there? Thank you for your help!
Unless the instructions call for an arrestor none needed. I wouldnt install a union. but if someone wanted a ball valve and or a union Id do it .
Are you running multiple threads on this ?
personage
Illinois
Sounds good, thank you. The instructions do not call for an arrestor. I was just wondering what the best practice would be, considering there was a capped tube near the old supply valve. I'll just leave it and run the line up to the new tank.
I am not installing a union, just a female adapter. There are two different threads. The tank inlet is G1/2, which is a British standard, but comes with an NPT adapter, so I am using that with a female adapter and a 90. I could not find a G1/2 to copper adapter, so it does look like a union with the NPT adapter sandwiched in the middle.
I did see you didnt show a union but you asked if you should install a union you could but I wouldnt bother just another possible joint to leak
