replacing Moen bath/shower trim
Discussion in 'Shower & Bathtub Forum & Blog' started by CentralTXPreacher, Sep 13, 2010.
  1. CentralTXPreacher
    CentralTXPreacher New Member
    Dec 9, 2009
    Central Texas
    First of all forgive me if I am not using the correct terminology when dealing with this. I'm a preacher and not a plumber!
    I am looking to replace the Moen bath/shower trim I now have (showerhead, arm, flange, escutcheon, handle and tub spout). We want to change everything to brushed nickel. I have a standard valve and only chrome comes in the standard valve. I was told I needed to get the moentrol and an adapter that would "retrofit" the moentrol to the standard adapter.
    Has anyone done this and did it work okay? Also did you have to get the valve with the trim. Seems like a waste to get the valve when it isn't going to be used. Due to cost I don't want to replace the valve.
    Hopefully this all made sense.
    Thanks in advance for your help.
    CentralTxPreacher
  2. jadnashua
    The cost of the valve is often small compared to the trim! I recently replaced my mother's tub/shower fixture. The rough-in valve was about $40, the trim was $160. This was a Delta (they also have a very wide range of prices and styles). On Delta, at least the version I bought, the cartridge comes with the trim. From a practical viewpoint, though, a new valve body means possibly a plumber, so yes, it does cost a lot to change out verses just changing the trim.
    If you can identify the valve you actually have, Moen can help you figure out what will fit. A picture of the valve and trim could help those here. Depending on exactly what you have, you may or may not be able to just replace the trim - they have more than one valve, and the trims are generally not interchangeable between dissimilar models and definately not between brands.
  4. Terry
    Aug 17, 2004
    Moen 145058 lets you use the new Posi-Temp trims. You don't need to buy the valve.
  5. CentralTXPreacher
    Dec 9, 2009
    Central Texas
    Terry,
    Thanks again for your help.
    CentralTxPreacher
  6. hj
    Moentrol and Dialcet, use the same trim. The difference between your faucet and a new one, however could be HOW the two holes are arranged. The older ones have them both at the bottom, while the new ones have them diagonal from each other. There is an adapter, however, that lets you use the new trim with the old valve.
Similar Threads: replacing Moen
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Replacing a three handle tub shower faucet with Moen Posi-Temp Feb 22, 2014
Shower & Bathtub Forum & Blog Replacing a MOEN bathtub faucet with a Kohler Mistos Oct 8, 2012
Shower & Bathtub Forum & Blog Replacing Moentrol shower control Jul 25, 2010
Shower & Bathtub Forum & Blog Replacing Trim and using old Moen Valve Sep 30, 2008
