Tree fingers
I am replacing my old bathtub but once I had the old tub removed I noticed that the tub's brass p-trap connection was rotted out. The far end of the brass p-trap pipe is stuffed inside an ABS pipe which then leads to the main waste line. My question is, well, what should I do? The brass pipe is in the ABS pipe very tightly so I'm not sure if I can pull it out with out breaking anything. Would I be better off cutting through the brass pipe and using a compression fitting?
Thanks in advance for all advice!
