Replacing bathtub p-trap
Discussion in 'Shower & Bathtub Forum & Blog' started by Tree fingers, Oct 3, 2013.
  1. Tree fingers
    Tree fingers New Member
    Oct 3, 2013
    Utah
    I am replacing my old bathtub but once I had the old tub removed I noticed that the tub's brass p-trap connection was rotted out. The far end of the brass p-trap pipe is stuffed inside an ABS pipe which then leads to the main waste line. My question is, well, what should I do? The brass pipe is in the ABS pipe very tightly so I'm not sure if I can pull it out with out breaking anything. Would I be better off cutting through the brass pipe and using a compression fitting?
  2. Terry
    Aug 17, 2004
    The ABS has a trap adapter on it, with slip joint nut and washer. It takes tublar fittings, which is what your brass tub drain is.
    You could use an ABS tub waste and overflow, and glue with coupling to the 1.5" ABS pipe.
    There should be a p-trap in there somewhere.
    [​IMG]
Similar Threads: Replacing bathtub
Shower & Bathtub Forum & Blog Replacing Bathtub Jan 6, 2017
Shower & Bathtub Forum & Blog Replacing bathtub shoe gasket Nov 17, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
Shower & Bathtub Forum & Blog Replacing a MOEN bathtub faucet with a Kohler Mistos Oct 8, 2012
Shower & Bathtub Forum & Blog Replacing bathtub in condo Sep 30, 2012
